240DL turn signal problem
Old Jun 1, 2006 | 11:01 PM
jktiffin's Avatar
Default 240DL turn signal problem
Turn signals do not work but emergency flashers do. Does that mean it is a relay problem? If so, what is a relay, how much is it, where is it,what does it do and how hard is it to fix?I am a real car ignoramus (don't even change the oil myself) but willing to learn.
Thanks
John
Old Jun 2, 2006 | 05:32 PM
cbevis's Avatar
Default RE: 240DL turn signal problem
check your fuse for the turn signals. Pretty sure the turn signals and hazards are on a different fuse.
Old Jun 2, 2006 | 09:12 PM
jktiffin's Avatar
Thank you for your help. You were right; it was indeed a fuse.... according to the manual the turn signals are on two fuses which I had not realized, so it was a very simple fix
Do you have any advice about a driver's side window that keeps coming off the bottom track? I have adjusted the bottom track but it does not seem to be horizontal, which seems to be the right position
Cheers!
John
Old Jun 2, 2006 | 09:19 PM
Alot of times the Rubber seal that is supposed to hold the window goes bad.
Allowing the window to come out of the track/regulator.
Also check where the regulator slides there should be red washers sometimes they will fall apart making the regulator have more play.
Old Jun 3, 2006 | 05:01 PM
jktiffin's Avatar
Was able to fix the window; when I compared it to the passenger side I noticed that one part was bent, so I straighened it out and it worked, though it does also need the rubber seal that the glass sits in. Where to buy?
Old Jun 4, 2006 | 02:41 PM
Haven't had to search the Aftermarket for one. Not sure if anyone sells them. Maybe the Dealer only.
suckonthiscaravan
Dec 5, 2018 03:19 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
gorogergo
Oct 1, 2005 01:20 AM
mdp61377
Jun 23, 2005 02:13 PM
