244 is missing when cold
Old Jul 7, 2020 | 02:17 AM
AlanMartinez's Avatar
Default 244 is missing when cold
My 1982 244 gas motor, automatic, mechanical fuel injection, starts up fine. When it is cold it misses noticeably. If I sit and wait until it is warm, bingo, suddenly is fine. What should I be looking for? The coil is good, spark plug wires fairly new, I believe the plugs are new also. So is the cap and rotor. Right now the weather is warm, so the miss lasts only a few minutes. I was planning on pulling wire on the motor when cold to see which cylinder is the issue. Any guidance would be great.
Old Jul 7, 2020 | 04:18 PM
Misses at cold temps can be a weak spark or a lean condition (possibly caused by an intake air leak or low fuel pressure). Did you check the plugs to see if one is fouled? How does the car idle?
Old Jul 7, 2020 | 04:28 PM
I have to pull the plugs but I know they were changed about a year ago... the idle is good... an occasional miss every 1 minute or so... I have never been satisfied with the look of the spark in this car... "looks" weak, but then so did my 84 244! Intake air leak? Hmm I will have to look at that... Thanks
indyisl7
Nov 29, 2023 01:05 PM
Offwhite
Jan 25, 2016 03:22 PM
Misfit
Dec 28, 2009 08:30 AM
HPO244
Mar 26, 2009 01:26 PM
swedishrocket
Dec 6, 2007 09:51 PM
