244 rotors or calipers?? Both?
Old Jan 30, 2006 | 11:45 AM
1982sherman's Avatar
Default 244 rotors or calipers?? Both?
Hi all
Just bought a 82 244 with 112000 miles very sweet. The car was used on and off the road and primarily used as a second vehicle. When I brake hard I can feel pulsing in the pedal, and when I slow to 10 KM/H I feel grabbing then OK then grabbing which to me is rotors warped. But I have read about calipers giving problems after they sit for awhile. Thanks Mike
Old Jan 30, 2006 | 04:36 PM
wojeepster's Avatar
Default RE: 244 rotors or calipers?? Both?
pulsating is likely to be caused by bad rotors
Old Jan 30, 2006 | 08:47 PM
Rotors........... Front makes the steering wheel shake. Rear you feel the pedal moving.
Old Jan 31, 2006 | 11:38 AM
mo t5's Avatar
My 95 Mustang has a shake when you use the brakes. I've got the optional 17 wheels from the factory. Think I'd be better off just changing rotors first, I think they are pretty cheap on this model.
Old Jan 31, 2006 | 09:16 PM
Yes but do you feel it in the pedal or the steering wheel?
Old Feb 1, 2006 | 11:49 AM
mo t5's Avatar
Alittle bit of both but mainly in the steering wheel.
Old Feb 1, 2006 | 08:48 PM
The steering wheel means the Fronts. I would do the fronts first and see how it is after that.
adamsrotors
39
Jun 25, 2015 01:01 PM
adamsrotors
49
Jun 25, 2015 12:58 PM
thegazelle
Jul 17, 2014 03:36 AM
jmoorhoff
Aug 16, 2005 04:39 PM
peterp105
Feb 1, 2005 09:06 PM
