frozen odometer 1987
Old Feb 1, 2006 | 03:06 PM
lizlatasa's Avatar
Default frozen odometer 1987
I am trying to register my old faithful 1987, and must have the odometer working again. i removed the instrument panel and checked all the connections. My radio doesn't work either, but I am just looking for the odometer repair.
I couldn't get the needle off to remove the metal cover over the speedometer and odometer , so i tore it off, but the cover won't slide out of the center hole.
I considered removing the metal cover with wire cutters and then slipping it out. I changed my mind, because tthe instrument panel is perfect, so i glued the needle back on, put it back together and I am asking for your help?
I can't find any diagrams or information on the odometer!! Help if you know how to get this little but critical gauge restored to rolling away the miles?
Thanks
Liz
Old Feb 1, 2006 | 08:59 PM
Default RE: frozen odometer 1987
Remove the electric motor for the odometer and check the gear.
krs2
Feb 4, 2010 11:57 AM
checksix
Dec 22, 2009 11:02 PM
peterpervy
Oct 25, 2007 12:54 AM
huzzsaba
Feb 13, 2007 07:11 PM
ulandt
Dec 21, 2005 02:15 PM
