244GL Air Intake
Old Jul 18, 2007 | 12:43 AM
Low_EF's Avatar
Default 244GL Air Intake
hey guys
My old mans 244GL is runing like crap. i took a look under the hood, and was quite confused when i saw a pipe going from the air box to the exhaust . The mechanic he goes to claimed its there to cool down the exhuast, but it looks to me that its sucking air from the exhuast...
being a car made in sweeden sorta makes sense.
My Question
can i rip this pipe out and either plug up the hole in the airbox, or run piping down to behind the front bar and have dual CAI?
anyone done this/got pics?
Cheers!
Old Jul 18, 2007 | 11:09 AM
S70driver's Avatar
Default RE: 244GL Air Intake
Sounds like it is the preheater pipe for cold climates.
Old Jul 18, 2007 | 12:50 PM
billofdurham's Avatar
It certainly is and it doesn't cool the exhaust it heats the air before it reachesthe filter element. However, inside the filter box there should be a preheating thermostat and shutter. If the air temp is high the stat should close the shutter and allow air to enter only by the other inlet pipe.
In many cases the stat jams over the years, sometimes with the shutter open and sometimes closed. If it ispermanently open it will affect the running of the car at normal running temp. In cold climates if it is permanently closed it will affect the running on first start up.
Check the shutter is closed when the engine is at normal running temp. If it is not thatcould be your problem.
1985.244GL.OK
May 29, 2010 09:44 PM
imbodie
Dec 9, 2009 03:32 PM
rquinonez32
Sep 30, 2008 02:08 PM
abrogard
Jul 19, 2006 10:41 AM
abrogard
May 22, 2006 08:54 PM
