245 rear seat release handle mechanism
Old Sep 6, 2014 | 09:58 AM
Fiataccompli's Avatar
Default 245 rear seat release handle mechanism
I am trying to repair/rebuild the seat release handle on my new-to-me 1990 245...seems the PO simply used pliers on the cables or a screwdriver on the latches to release the seat, but I was hoping to clean it up a bit. I picked up a good handle mechanism from a 940 that is the right color and not broken, but I am still missing some of the white plastic internal parts I think...anyone have or can point to either photos or an exploded view of how this release handle is supposed to be put together?
Thanks in advance
Old Sep 6, 2014 | 02:57 PM
240 and 740/940 wagon rear seats are considerably different. not sure any parts are interchangable.
here's the parts diagram for the 240...
Rear seat 5-Door. Fits: Volvo | VolvoPartsWebstore.com
the 7/9's have a split seat, single on the right, double on the left.
here's the 7/9 (up to 1992) right rear seat
Rear seat Right 5-Door -1992. Fits: Volvo | VolvoPartsWebstore.com
and left...
Rear seat Left 5-Door -1992. Fits: Volvo | VolvoPartsWebstore.com
(1993- are somewhat more complex)
So... are you talking about the seat bottom release, or the seat back release?
Old Sep 6, 2014 | 03:33 PM
Thanks. It is the seat back handle that is messed up in my 245. I am 99% sure the plastic parts (handle, guide and trim are the same on the 945 (which has one for each side) based on photos I've seen.
Old Sep 6, 2014 | 04:43 PM
well, match the PN's of the bits between that 240 and 940 page. they appear completely different to me.
note thats a Volvo dealer's website, if they list the parts, they are still available for the 240 from a dealer. this dealer website has about 30% off (+/-) MSRP.
Old Sep 7, 2014 | 07:47 AM
Thanks...from what I gather (including mining an 88 245 in a salvage yard), the handle changed in 89. Most vendors seem to list only the 89-93 type and the photos look exactly like the one I pulled from a 945....but what is different is the interface with the two release cables, so that is what I'm looking for a view of. I think I've figured out how I can make what I have work (reliably and without cosmetic hacking), but I think I'm still missing part of the correct cable interface and it looks like the replacement handles do not include it. I was not able to get a clear detail of the configuration on that exploded view and it seemed like it was showing the older style seat. Anyway, I am sure. I'm missing something silly here and thanks for the feedback
Old Sep 7, 2014 | 02:37 PM
i found that diagram using the part numbers for a 1990 240.
part 32 on this diagram is the control handle for 1989- ... part 34 is a spring nut for 89- 33 is the cable anchorage. 35 and 32 appear to be key bits, too.
all the part numbers and prices are down below.
Old Sep 7, 2014 | 04:18 PM
Yes...that shows the two types. Bingo. .thanks
Old Sep 18, 2014 | 10:14 AM
Hey - just to close the loop on this, here's what I found: the 945 seat handle plastic assembly does, in fact, work in the 245 (at least on my 1990 245). the 945 makes for a good parts offering as the split seat means there are two handle mechanisms in each car you find! Also, you can easily find a tan interior so you are not stuck with the new, black handle. That said, I was lucky in that I found car in a local salvage yard that had clearly been indoors a good bit of its life and thus the plastic was not powdery like a lot of aged Volvo plastic becomes.
So, the handle on the 945 appears to be the same in design as the 245 for this later series rear seat. I tried using the 2 lever style that may have been used in earlier 245s and had no luck, but using the cable bracing that is original to my later 245 I was able to use the 945 handle and the only part missing was the attachment from the handle to the inner cable end. I used a 1" (or so) washer in which I drilled 2 holes to draw the cable through...seems to work quite well....so, it's a bit Franken-built & a bit re-engineered, but cleaner than exposed cables and vice grips or a long screwdriver on the latches. If anyone else is in this situation, I can provide some elaboration....sorry, but I did not take a photograph of the Frankenmechnism...
rmmagow
1998-2000 model year V70
Jul 9, 2012 01:25 PM
Heath7
Mar 13, 2011 11:09 PM
fivekampers
Oct 19, 2009 07:04 PM
TMac
Apr 23, 2009 09:21 AM
cameron
Sep 11, 2006 08:25 AM
