5 Speed or 4 Speed + Overdrive?
Old Aug 17, 2016 | 02:13 AM
noexit's Avatar
Default 5 Speed or 4 Speed + Overdrive?
All other things being equal, would you choose a 5 speed B47 or 4 speed B46 transmission, and why?
Are 240s with one harder to come by than the other?
I have the opportunity to buy a 87 240 with a 5 speed, but there's a nicer 85 245 for a little bit more. Or I can wait on a nicer 5 speed. Just looking for thoughts on the subject.
Old Aug 17, 2016 | 09:06 AM
lev's Avatar
lev
The 46 is stronger, the 47 can't handle turbo cars... I personally like the ancient "weird" top button overdrive but it's got issues, electrical mainly...
The 47 is a true 5 speed but is more fragile, gears are known to fail early, can't really be repaired.
Old Aug 18, 2016 | 01:27 AM
noexit's Avatar
But if I'm going for a naturally aspirated engine, no turbo, is there a big difference? The 47 is lighter by quite a bit isn't it?
Old Aug 18, 2016 | 02:36 PM
lev's Avatar
lev
Well, I don't know for sure but doubt it's significantly lighter... 10-20 lbs may be.
Old Aug 18, 2016 | 02:41 PM
Cwazywazy's Avatar
If you're going NA I'd go for the 5 speed just because it's easier than the overdrive. Probably less likely to break than the overdrive as well.
Old Aug 18, 2016 | 04:26 PM
lev's Avatar
lev
Actually, no... The M47 is way more fragile than the M46, and as far as ease of driving, one pushes a button to go into O/D, one has to be shifted into 5th. Technically, easier to push a button than to shift into a whole new gear...
Old Aug 18, 2016 | 06:46 PM
noexit's Avatar
Well, looks like I'm looking at a nice 82 245 Turbo tonight, so maybe I won't go NA after all.
Old Aug 23, 2016 | 05:51 AM
diesel4me2's Avatar
Default M46 is best
M46 is a much better gearbox . Was very expensive to produce so Volvo went on the cheap... and now we have the M47.. absolute junk...
Old Aug 28, 2016 | 10:33 PM
beleive's Avatar
it will be hard to find a m47 in good shape. So, in that case I would rather put my money in a m46.
lilsilver85
Aug 29, 2014 04:07 AM
S-40
Oct 15, 2013 05:32 PM
sdc2000
Jun 29, 2009 04:52 AM
iamnickcarter
Oct 29, 2007 01:03 AM
parrym
Nov 7, 2004 11:30 AM
