740 doesn't shift up to 3d.
Old Jun 29, 2011 | 03:52 PM
bob330's Avatar
Default 740 doesn't shift up to 3d.
I have a 1987 740 turbo wagon that will shift fine up to second, but there it stays. Are there issues other than a bad transmission that I could be looking into? The turbo did stop working about a year ago. thanks for considering this.
Old Jun 29, 2011 | 04:43 PM
lev's Avatar
lev
If the fluid is not too low, then the tranny needs internal help...
Old Jun 29, 2011 | 06:01 PM
bob330's Avatar
yea fluid is good. Replaced it and the filter and tried a can of "treatment" recommended by the local transmission guy with no results. I can try to score a used transmission, but didn't want to jump the gun on that job. Thanks
Old Jun 29, 2011 | 07:57 PM
swiftjustice44's Avatar
Was the old fluid burned and/or discolored? Can you not get it to shift into 3rd at all? Not by accelerating briskly and take pressure off the gas pedal? Not by manually shifting? If not, it's fubar'd. If/when you search for a replacement, be sure you get an AW71 or AW71L from a turbo. The standard AW70 will not stand the additional torque of a turbo. I say this from experience; I blew an AW70 w/ 125k on it in less than 2 weeks behind a turbo motor.
Old Jun 29, 2011 | 09:16 PM
bob330's Avatar
The fluid looked good and can't get it into 3d at all...Thanks for the wisdom on the AW71.
jivago
Jun 21, 2019 09:08 PM
95 850
Mar 27, 2012 06:37 PM
SlikRick
Aug 28, 2011 09:47 PM
740 Volvo
Jul 22, 2005 02:23 AM
