740 electric problem
Old Sep 17, 2011 | 11:32 AM
740-TURBO's Avatar
Question 740 electric problem
Sometimes when I start my car the whipers and radio don't turn on, but sometimes when I start my car they do. What is the problem here?
Old Sep 17, 2011 | 11:37 AM
740-TURBO's Avatar
I'd say that its a 75:25 ratio (Not working to working)
Old Sep 17, 2011 | 04:24 PM
Joseph/TX's Avatar
Try wiggling the key next time it happens. Possible worn ignition switch.
Old Sep 18, 2011 | 11:16 AM
740-TURBO's Avatar
Thanks, I'm going to try that today, is it expensive to get that replaced?
Old Sep 18, 2011 | 11:22 AM
740-TURBO's Avatar
1985-1992 Volvo 740 Ignition Lock Assembly - Steering - OES Genuine 85-92 740 Ignition Lock Assembly - 821-01058862 - PartsGeek
not bad at all, has anyone ever installed one of these?
Old Sep 18, 2011 | 03:19 PM
Joseph/TX's Avatar
Replacing the part that goes out - the electrical part - isn't all that bad. I think I popped the cluster out on my 240 to make it easier to access; I forget what I did on the 740, but I have successfully removed switches from both models at the wreck yard in less than half an hour. Replacing the lock assembly is a PITA, but that's not gonna be your problem. The link in your last post is for the locking part, which is not what you would need.
Old Sep 19, 2011 | 04:26 PM
740-TURBO's Avatar
Jiggling the key worked today, I'm just going to ride that out for as long as I can
Old Sep 19, 2011 | 08:10 PM
I had a similar problem with a few of my 960's. The deal with it was that the key did not return to the II position after I released it from start. What I did was turned the key back just a little after each start. This solved several problems and I drove the car like that for a couple of years. I actually looked at it as a security feature.
VOLVORRD
Aug 27, 2014 12:02 PM
Underforte
Jun 20, 2013 08:13 PM
codynidaho
Jun 6, 2011 10:02 AM
bmac
Apr 28, 2011 05:40 PM
Kruspe31
Feb 27, 2008 08:53 PM
