740 GLE Running Rough
Old Jan 27, 2012 | 12:02 PM
Salinsh's Avatar
Default 740 GLE Running Rough
could someone give me an opinion: volvo 740 2.3 16v engine code B234F 155bhp, the car came to head gasket change, before and after words it didn't run well and died, but when it runs it detonates(shoots) in the inlet manifold on quick accelerator pushing.
timing belt marks are good checked.
throttle position sensor changed
idle air control valve works checked
spark plugs and wires ok
distributor changed
ignition control unit changed
still doesn't run
what could be the problem?
Old Jan 27, 2012 | 11:05 PM
swiftjustice44's Avatar
Sounds as if timing is not correct. Re-check your timing and also the distributor installation.
Old Jan 28, 2012 | 04:43 AM
Salinsh's Avatar
fault code 3-1-2 is also displayed
Old Jan 28, 2012 | 06:27 AM
Here is an article that may help a bit...
RWD -
nick59349
Mar 4, 2013 09:34 PM
sgvolvo
Sep 24, 2012 02:21 PM
Mannkar
May 22, 2004 03:34 PM
Mannkar
May 19, 2004 02:48 AM
Mannkar
May 19, 2004 02:15 AM
