Quick question on TPS
Old Jan 27, 2012 | 10:04 PM
JTK's Avatar
JTK
Default Quick question on TPS
I am in need of some expert advice for my '92 740 B230F. I was playing around with the TPS today. Is it 'normal' for the car to idle and rev just fine with the TPS unplugged on a hot engine? Starting the engine with the TPS unplugged when cold will cause the engine to stall within a few seconds. The sensor is adjusted so that it 'clicks' as soon as the throttle moves. I am asking because I'm trying to diagnose a rough idle on start issue and am going though the list of possibilities. Any suggestions would be greatly appreciated.
JTK
Old Jan 28, 2012 | 06:48 AM
swiftjustice44's Avatar
What you describe seems normal to me. I always equated the TPS as analogous in some respects, to a carb's choke circuit. Is your rough idle on hot starts, cold starts? Sometimes covering all the basics first eliminates some of these annoying habits our aging cars develop. Have you removed the TB, cleaned it thoroughly and renewed the gasket if necessary? Plugs, cap, rotor, wires? Any codes?
Old Jan 28, 2012 | 07:13 AM
jagtoes's Avatar
JTK
Use this as a guide Engine: Fuel Injection Body and Throttle Position Switch Adjustment
Old Jan 28, 2012 | 09:39 AM
JTK's Avatar
JTK
Thank you for the advice on the TPS. I cleaned it out two years ago and it really needed it. I checked it again last year and looked great, put in a new gasket while I was at it. Plugs, cap, rotor and wires are new within the last six months. Strangely, no engine codes. I actually have a separate thread going on the rough idle if you are interested in reading up on it.
https://volvoforums.com/forum/volvo-...problem-60094/
I'm going to be replacing some coolant hoses next weekend and hopefully can get some work done on the intake system while I'm at it.
Thanks again for the reply, I am always open to advice.
JTK
240nc
Mar 9, 2015 10:02 PM
Phil 850
Jul 16, 2012 10:16 PM
volvoguy23
Mar 24, 2012 09:39 AM
knookie
Jun 9, 2006 09:52 PM
DENNISVHANK
Oct 22, 2005 02:49 PM
