740 low then high idle
Old Sep 4, 2011 | 10:36 AM
bdraht's Avatar
Default 740 low then high idle
My 85 740 turbo when starting the rpms go to 1500, then drop to almost 0 then they will even out at 1000. When driving coming to a stop they will drop to almost 0 then bounce back to 1000. Normally this car would idle at 800. This problem surfaced after the car quite at the side of the road. It would run but barely, but the next day it ran well enough so we didn't have to tow it. Had a problem with car dying in hot weather, just replaced in tank pump, mas air sensor connector and high tension lead from coil to distributer.
Old Sep 6, 2011 | 09:59 AM
bdraht's Avatar
Replaced idle control valve and problem solved. I also replaced some poor vacuum hoses just for good measure.
Dennis Bor
May 30, 2011 11:14 AM
mstrplmber
Jun 26, 2010 04:10 PM
rosesforlily
Nov 5, 2009 09:23 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
elderzap
Nov 7, 2007 04:58 PM
