740 pinion angle
Old Dec 13, 2017 | 02:18 PM
jagtoes's Avatar
Default 740 pinion angle
Does anyone know the pinion angle for a 1989 740 GL with automatic transmission. Just trying to verify what it is .
Old Dec 13, 2017 | 05:03 PM
you referring to the angle of the differential input shaft? it should be close to exactly parallel to the transmission output shaft when the suspension is loaded normally, or maybe slightly compensated for the amount of rear end squat under heavy accelleration (eg, so that its parallel when you're accelerating). the 740 thrust bars do a pretty good job of keeping it square.
Old Dec 13, 2017 | 08:27 PM
jagtoes's Avatar
Thanks as I assumed it was some (?) degrees neg. (down) as opposed to 0 and parallel.
Old Dec 14, 2017 | 03:26 PM
its pretty much locked in place by the thrust rods... if the bushings on those are shot, then there's slop, which can lead to driveline vibrations.
those are bushings 32, 33, 35, 36 on thrust rods 31, 34.... I suppose its also possible for the braces 18,19 to be sloppy if the isolation bushings 21 (2x), 24 are shot but I've not seen one that far gone, I suspect if they were badly worn, you'd be getting a lot of clunks in the chassis when you go on/off throttle.
Mr. Benedict
May 30, 2007 08:14 AM
jguerra3235
Mar 21, 2007 01:34 AM
antlers
Dec 28, 2006 10:11 AM
sharifsm
Dec 21, 2006 01:45 AM
bernielomo
Jun 5, 2006 09:16 PM
