740 sedan - headlight lens replacement
RE: 740 sedan - headlight lens replacement
Tech ....thanks for replying.
I have the entire headlight (lens & black plastic housing are sealed). In looking at the existing headlight, above the light assembly, there are two 5/8" plastic fittings which turn screw threads into theholes in theplastic housing.When I turn one of these 5/8" fittings, the headlight moves in/out depending upon clockwise/counter-clockwise rotation. I don't believe these fittings are for horizontal/vertical beam alignment.
Does my explanation make any sense to you? I would appreciate your help with this project.
Thanks man
Thanks man
