740 Starting Problems
Old Jan 11, 2005 | 04:50 PM
VolvoLisa's Avatar
Default 740 Starting Problems
I just bought a 1990 740 and it's a great car when it runs, its perfect. The problem is when it gets warmed up like after a lengthy trip of at least 15-20 minutes it will not start back up until it cools off. Has anyone ever come across this problem before?
Old Jan 11, 2005 | 05:34 PM
Default RE: 740 Starting Problems
I would try to replace the coolant temp sensor.Thats what it sounds like to me.I have seen that many times with these cars.
Old Jan 12, 2005 | 02:15 PM
auser's Avatar
Have same problem with 1990, 740 GL. Hot soak problems are very common with high mileage 700/900 models. I have replaced a defective fuel pump relay, coolant temp. sensor and fuel pump check valve and cleaned the ignition coil. The fuel pressure is ok and I get sparks but problem still there. I plan to change the RPM sensor next. Good luck and don't give up.
Old Jan 13, 2005 | 09:55 PM
auser's Avatar
I changed the rpm sensor, it was in poor shape. Still same problem. This evening I switched the radio suppression relay with the cooler fan relay and the car now starts right away. Figures, the problem is the easiest to fix and the least expensive. I just ordered 2 new relays from eEuropeanparts.
Old Jan 14, 2005 | 12:16 AM
That would have been my next guess.Those cars were weird some of them had those relays and some didn't.Thats why I didn't suggest that first.Im glad you got it figured out.The speed sensor would have given you problems soon if it was in bad shape.
Old Feb 22, 2005 | 02:29 PM
VolvoLisa's Avatar
I replaced the radio suppression relay and it didn't help. I have just ordered a new speed sensor, hopefully this will correct it.
Old Feb 22, 2005 | 05:19 PM
Let me know how you make out.
Old Mar 10, 2005 | 10:42 AM
bli745's Avatar
try fuel and radio relays
Old Mar 21, 2005 | 11:16 PM
VolvoLisa's Avatar
I finally replaced the speed sensor (it was lost in transit) it worked! It runs beautiful now.
Old Mar 22, 2005 | 01:48 AM
Im glad you got it fixed.
abyjake740wg
Dec 9, 2008 01:10 PM
monolith
Apr 16, 2008 12:40 AM
penkogj
Aug 23, 2006 10:07 PM
penkogj
Jun 24, 2005 09:49 AM
bigb1rd
Mar 1, 2005 09:59 AM
