740 Stops suddenly
Old Sep 9, 2005 | 10:59 AM
kem041175's Avatar
Default 740 Stops suddenly
Hi,
My 1990Volvo 740 with 2.3 litre engine and automatic transmission sometimes stops when i am driving. This can happend if i drive normally in 80-90 km/h. This happends about once a week. When it stops, i just let i roll in Drive, and it starts again after 5-10 seconds. It does not help if i press the trottle or not. I have changed Plug-wires, but itdid not help. Any other idea?
Old Sep 9, 2005 | 04:15 PM
matthewensey's Avatar
Default RE: 740 Stops suddenly
Are you saying the engine cuts off, then restarts after a few seconds?
Old Sep 9, 2005 | 08:43 PM
It could be many things.
It could be a bad massflow sensor,speed sensor,fuel pump relay,fuel pump, ETC
Old Sep 9, 2005 | 10:08 PM
Carbuff's Avatar
ORIGINAL: tech
Interestingly, just got the new IPD newsletter/catalog today and it has a write-up on just this type of problem. (In the article, the cause was the fuel pump/radio supression relay. No fuel to injectors when hot.)
Old Sep 9, 2005 | 10:36 PM
Yes the black relays are known to go bad.
The easiest way to test is to swap plugs with the cooling fan relay next to the one for the fuel pump.
gotdurt
May 25, 2012 06:39 AM
Paul Haugh
Jun 8, 2011 08:30 PM
wagoon
Jan 27, 2009 09:23 PM
1990TURBO740
Jul 13, 2008 08:16 PM
mill_farm
Jul 27, 2007 08:48 PM
