740 turbo suddenly blowing oil out of dipstick tube and exhaust
Old May 14, 2019 | 04:07 AM
86744ti's Avatar
Default 740 turbo suddenly blowing oil out of dipstick tube and exhaust
Hi guys ! 86 740 ti was running good then oil started erupting out of the dipstick tube and out of exhaust like crazy. White smoke like thick, I checked oil trap and fire trap, all good !
Turbo seals maybe ? Please help , i am stuck !
Old May 14, 2019 | 10:34 AM
could be a turbo seal, could be a head gasket or a broken ring. Did you do a compression test?
Old May 14, 2019 | 04:39 PM
86744ti's Avatar
Default Have oil blowing out the exhaust
Yeah checked the turbo , no broken rings and head gasket seems okay have compression, something plugged up somewhere ?
Old May 14, 2019 | 07:17 PM
jagtoes's Avatar
Did you check your coolant. No oil in it and did you check your oil to see if there is any coolant in it. If your PCV system is not blocked then check the oil lines to the turbo. Sounds like a head gasket.
86744ti
May 14, 2019 03:53 AM
ajamesr
1998-2000 model year V70
Aug 4, 2012 01:56 AM
BB Roller
Feb 27, 2011 06:28 PM
chrisk
Jun 21, 2010 06:19 AM
trooperone
Apr 22, 2009 12:01 AM
