740 turbo turns over-wont start
Old Aug 21, 2008 | 06:05 PM
tdpetree's Avatar
Default 740 turbo turns over-wont start
I have an 87 Volvo 740 Turbo, 178,000 miles. She will not start. Turns over fine, but just wont start. I have replaced so far: in-tank fuel pump (in-line pump functioning fine), distributor cap and rotor, spark plugs, spark plug wires, radio supression relay... all with no luck. She cranks over, every once in a while fire for a second or two, then goes back to cranking. For the past couple months, she would die while driving her, then start up after about 5 to 15 minutes. Now she wont even start. I am at a loss, can anyone else give me any ideas please. Thanks!!
Old Aug 21, 2008 | 09:32 PM
Default RE: 740 turbo turns over-wont start
When it won't start do you have fuel,spark,and injector pulse?
Old Aug 21, 2008 | 10:26 PM
khooper's Avatar
It is a short somewhere in the electrical system. I have had several short circuits in mine. One was a wire shorting out on my power door lock relay. One short created a burned out fusable link. I have also had to replace the ignition module several times. I eventually bought a brand new wiring harness and replaced every circuit.
__________________________
Check out : Oxygen Sensor Wholesale
Old Aug 24, 2008 | 11:50 PM
jdh0921's Avatar
Heya
I would check for fuel and spark. Take out each plug and connect to the Plug Wire and ground it out on the block. If you get a solid blue block your good.
When i checked the fuel, I took 4 empty soda bottles and put them on each injector and see if you are getting a good spray and also that you are not leaking.
These two will help dictate whether its an electrical problem or a fuel problem.
Hope this helps
JH
Old Aug 26, 2008 | 11:03 PM
fredbyte's Avatar
Go to www.stepbystepvolvo.com and download the free 740 no-start guide.
Jerry Balch
1998-2000 model year XC70
Feb 15, 2014 11:51 PM
iamcanadian
Jul 15, 2012 05:26 PM
steelheaddan
Jul 23, 2011 12:18 PM
GaryBrad
Jan 4, 2008 09:50 AM
