740 wagon issues
Old 08-29-2008 | 08:07 AM
aroger745's Avatar
Default 740 wagon issues
Just a bought a 740 wagon -1992 with 135,000 miles. Replaces a 245 with 212,000 miles which replaced a 245D with 320,000 miles. So I am moving up...maybe. The car is great, but needs two fixes which will drive me nuts. First - the lift gate can't be opened from the outside latch. Need to use the inside latch via a broomstick. Inconvenient. Anyone with a likely cause? 2: Electric locks don't work. Before I take off the left front door panel and start probing with a meter, anywhere else I should look or a common point to test all the other remote actuators? How do the lift gate and left front door panels come off? I have Chilton, but it simply says to proceed very carefully....duh. I needed that advice.
Old 08-29-2008 | 10:27 AM
blue goose's Avatar
Default RE: 740 wagon issues
Before you remove door panels, check the controlling fuse and the central locking and unlocking relays. Not sure about the specifics of a '92 740. My car has two such relays behind the center vent on the dashboard.
andrewma
05-16-2018 02:47 PM
pierce
12-10-2010 03:08 PM
volvoQ's
09-26-2010 02:45 AM
Glockness
04-07-2008 08:36 PM
Quick Reply: 740 wagon issues
