740 ZF auto trans in an 1988 240
Old Nov 2, 2013 | 08:03 PM
Travanion's Avatar
Default 740 ZF auto trans in an 1988 240
Anyone tried it yet? I am wondering if I used the dip stick tube and cooler lines from the 740 would it work? Would in need to use the drive shaft from the 740?
Old Nov 2, 2013 | 08:24 PM
lev's Avatar
lev
Tried what? Swap a ZF for AW? Parts mentioned won't just swap over... Should research the drive shaft issue: 740's used both ZF (early), then went to AW.
Old Nov 2, 2013 | 09:20 PM
Travanion's Avatar
Wondering if I could put the ZF in place of a bad AW if I had access to the whole 740 car. I figured since 740s got AW also the ZF stuff might work in a 240.
Old Nov 3, 2013 | 01:59 AM
the AW7X were a major upgrade in reliability, durability, and strength.
you'll need a different driveshaft as the transmissions are different lengths. the 240 and 740/940 driveshafts are different sizes and center bearings, and everything.
Old Nov 3, 2013 | 07:37 AM
Travanion's Avatar
Thanks again Pierce, yeah it was the hair brained idea of a desperate fool.
nortons
Feb 22, 2015 11:14 PM
Incursus
Feb 27, 2014 03:37 AM
VolPat
Jun 15, 2012 08:06 PM
repeatclicks
Sep 3, 2007 07:57 PM
mktmkt
Mar 31, 2005 02:38 PM
