740GLE Engine Start Troubles
Old Nov 30, 2010 | 04:33 PM
kyuen_chu's Avatar
Default 740GLE Engine Start Troubles
Hi,
I did a quick search of the forums and it doesn't see anything that matches my case exactly, so here goes.
1990 740GLE. For a while now when the car is at low idle it shakes and once in a while the engine dies and I need to put the car into park then start the car again. Most of the time it'll start, but at stop lights the car shakes and sometimes dies
The other day, I started the car and it went to idle for maybe a second or two, then I shifted to drive and engine died. Put the car in park, tried starting the car again. Started for a second, engine died again. Repeat this another 3 times - was unable to start the car and get it to run.
Any ideas? I have a feeling it might be an issue with the timing belt issue, but not 100% sure. Thought I'de see what you guys think.
Old Nov 30, 2010 | 07:26 PM
ed7's Avatar
ed7
Check fuel flow: filter and pressure. Check plugs, wires, cap and rotor, coil wire and coil connections. Start simple then go hard/ expensive.
Next on your list, crank sensor.
http://www.stepbystepvolvo.com/Resou...20No-Start.pdf
Ed
Old Dec 2, 2010 | 10:28 PM
lev's Avatar
lev
you need to start by doing a "tuneup"... not timing belt or fuel issue... is this a regina car, b234?
volvo740wa2
Aug 31, 2015 07:08 PM
Beardog
Dec 7, 2009 02:06 AM
volvoforums53
Jul 18, 2006 12:03 PM
mrbaja
Dec 17, 2005 03:41 AM
lenniefoug
Dec 4, 2005 11:30 AM
