740T vacuum lines...
Old Aug 21, 2014 | 06:55 PM
Default 740T vacuum lines...
anyone know why there's a vacuum line off the riser pipe from the oil seperator box to the main vacuum T on a 1992 740 turbo?
the vacuum nipple on that hose connector just snapped off... the big hose goes to the intake upstream from the turbo, so I'm having real trouble figuring out why vacuum is connected to it.
and, geez, getting the crusty old piece of vacuum line off the EGR actuator, arrrrgh, its wedged in behind the idle air control valve, and short of taking the whole thing apart, I flat out can't get the clamp off or the broken off stub of hose.
Old Aug 21, 2014 | 08:42 PM
TIPSP's Avatar
Got Boost?
You could just put a filter on the end of it and vent it to the atmosphere, but you're in Cali right? Smog laws wouldn't let that slide.
The air/vapors from the seperator are burned within the engine.
Old Aug 21, 2014 | 11:07 PM
yeah, I realize the crankcase fumes are burned... they are plumbed over before the turbocharger via a relatively thick pipe, I'm just wondering why there's also a skinny vacuum line connected to it. on a turbo, vacuum can be 7PSI boost.
Old Aug 22, 2014 | 03:45 PM
lev's Avatar
lev
I don't know exactly why, may be a breathing balance for the whole system... But I do know that that little nipple on the turbos' fitting gets all hard, and clogged, and it breaks. It's a cheap part to replace.
j_h_buckley
Mar 28, 2009 09:46 PM
1996850turbo
Oct 1, 2008 10:14 AM
goober4321
Aug 29, 2008 06:31 PM
jmana
Sep 8, 2007 04:13 PM
reynrog
Jan 7, 2006 12:36 PM
