780 Starting Issue
Old Mar 25, 2008 | 09:25 PM
780Coupe's Avatar
Default 780 Starting Issue
Hello,
I have an '89 780 4 cyl. Turbo I've owned for several years. For the past three, my sister has been using it has her primary transportation.
The car has 140k, and all maintanence has been taken care of since new. The last time I had it in the shop for a tune-up, I was told everything was fine.
Just tonight, she was driving home when suddenly the radio and power to the brakes and steering went out. The car slowly lost power and she shut it off. When I arrived, all accessories and lights operated fine, but the car would just not crank. There were no clicks, just nothing.
All help in this matter would be greatly appreciated.
Old Mar 26, 2008 | 02:48 PM
billofdurham's Avatar
Default RE: 780 Starting Issue
Check both leads to the battery for tightness and cleanliness. Make sure that the earth (ground)lead is clean and tight where it joins the chassis/frame. Also check the earth (ground) lead from the engine to the frame.
Old Mar 26, 2008 | 04:27 PM
780Coupe's Avatar
Thanks for the tips. I checked the battery connections and they were filthy. I was able to get it started, so it's now in the shop.
780 Freak
May 23, 2012 12:55 PM
Dads850
Jan 14, 2008 10:41 AM
Pteezy
Aug 14, 2006 01:02 AM
pincky
Jun 20, 2006 02:24 AM
