82 242GT Digital Ign. HELP!!
Old Oct 22, 2008 | 11:06 PM
83242GT's Avatar
Default 82 242GT Digital Ign. HELP!!
ok so first off ive got an 82 242 turbo, with a stroked 2.3 in it...everything is stock...except the head and block duh. now, My buddy gave me a Mallory HyFire A6 box, part # 6852M. now, it has no instructions with it at all, but before he lost them he set in in 4cyl. mode, so thats all set...I would like to put it in the 242 but with no instructions im very lost. anyone have any ideas or anyone thats done this can you help? Ive got, black and red main batt. power wires, small purple and green wires, small red wire, larger (16guage) orange, black, yellow, orange, and white wires....so...where do they go? anyone? thanks
Old Oct 23, 2008 | 12:27 AM
TIPSP's Avatar
Got Boost?
Default RE: 82 242GT Digital Ign. HELP!!
Here is the pdf instructions: http://www.mr-gasket.com/pdf/6852M_6853M.pdf
Here is a clip of the PDF:
WIRE FUNCTIONS
Power Leads
The two heavy gauge wires (14 gauge) that deliver battery voltage
to the ignition:
Heavy Red
Connects directly to the battery positive (+)
terminal or to a positive battery junction. It could
also be connected to the positive side of the
starter solenoid.
NOTE: Never connect this wire
to the alternator.
Heavy Black
Connects to frame or chassis ground.
Trigger and Coil Leads
Small Red
Connects to a switched 12 volt source, such as
the ignition key.
Orange
Connects to the positive (+) terminal of the coil.
NOTE: This is the only wire that makes
electrical contact with the coil positive (+)
terminal.
Small Black
Connects to the negative (–) terminal of the coil
electrical contact with the coil negative (–)
terminal.
Trigger Wires
Either of two circuits will trigger the HYFIRE® 6A
Ignition Control: a points circuit (white wire) or a
magnetic pickup circuit (violet and green wires).
NOTE: The two circuits will never be used
together.
White
Connects to points, electronic ignition amplifier
output or to the green wire of a Mallory timing
accessory. When this wire is used, the magnetic
pickup connector is not used.
Violet/Green
These wires are routed together in one harness
to form the magnetic pickup connector. The
connector plugs directly into a Mallory distributor
or crank trigger. It will also connect to factory
magnetic pickups or other aftermarket pickups.
The violet wire is positive (+) and the green is
negative (–). When these wires are used, the white
wire is not used. Consult the chart that shows the
polarity of other common magnetic pickups
Yellow
Connects to the tachometer.
Old Oct 23, 2008 | 01:11 PM
83242GT's Avatar
Hey thanks a bunch, I was having a hard time finding stuff online, its in now and working perfect, now i just have to mount it and make the wiring a little cleaner (get rid of the tape) haha.
Old Oct 23, 2008 | 03:25 PM
TIPSP's Avatar
Got Boost?
Sweet. Love to see some pics of your set up.
mikde
Feb 16, 2014 08:59 PM
kazz242
Apr 13, 2009 10:54 AM
83242GT
Oct 27, 2008 01:05 AM
bbruneau
Sep 19, 2008 06:51 PM
ROBG
Jan 3, 2008 08:02 PM
