1999 S70 IGN.LOCK
Old Jan 2, 2008 | 04:09 PM
ROBG's Avatar
Default 1999 S70 IGN.LOCK
Hello group,nice to meet you all my name is Rob. I would like to know ifa softwear down load is neccessary when the
ignition lock is replaced. I now have ignition switch unplug-
ged and car starts. Ignition switch only turns to position #1
Thanks for all and any info.
Rob
(car is a 1999 S70GLT)
Old Jan 2, 2008 | 06:23 PM
ROBG's Avatar
Default RE: 1999 S70 IGN.LOCK
Up-date. No softwear down load needed w/replacing ignition
lock cylinder. It takes 7-10 working days to get coded lock
cylinder from dealer,order by vin#.
rob
Glad you figured it out.
Old Jan 2, 2008 | 06:44 PM
ROBG's Avatar
Well Tech I'll know in 7-10 working days if i indeed figured it
out. Thanks for your reply. This being my first post here it is
nice to know someone is reading the posts. I will post again
if I have a problem with switch replacement.
Thank again
Rob
Old Jan 2, 2008 | 06:48 PM
It will be a little bit of a pain.
You are supposed to drill and easy out them.
But I usually take a chisel and cut around the shear off bolt and break the aluminum out so it comes off.
But you also have to be careful some of the new ones don't come with the top half anymore.
Old Jan 3, 2008 | 10:52 AM
ROBG's Avatar
Thanks for the heads up on the part,I think I will wait for the
new part to arrive before I proceed to "HAMMER TIME".
Thanks again.
Rob.
Old Jan 3, 2008 | 08:02 PM
Let me know how it goes.
kejonespequa
May 24, 2011 07:33 PM
mcaanda
Oct 31, 2010 09:17 AM
83242GT
Oct 27, 2008 01:05 AM
83242GT
Oct 23, 2008 03:25 PM
bbruneau
Sep 19, 2008 06:51 PM
