82 245DL wont start
Old 10-19-2008 | 01:57 PM
white out's Avatar
Default 82 245DL wont start
My aunts n/a 82 DL was working this morning. Now it will not start. This information is being relayed to me from my Aunt who is with the car.
It wont crank, can hear the fuel pump prime, and pushed the distributor cable back down (it was loose). Apparently it wont start when jumped either.
Any ideas?
Nick
Old 10-19-2008 | 02:30 PM
blue goose's Avatar
Default RE: '82 245DL won't start
Give the starter motor a good rap with a broom handle and try it again. Could be the starter solenoid.
Old 10-20-2008 | 09:00 AM
white out's Avatar
Also, it had a new voltage regulator installed about two weeks ago.
Nick
Old 10-20-2008 | 09:06 AM
white out's Avatar
Does anybody know what fuse may be preventing it from starting?
Nick
Old 10-20-2008 | 09:08 AM
I agree with the starter as well. If it won't turn over then the starter isn't turning.
Old 10-20-2008 | 07:05 PM
fredbyte's Avatar
If it won't crank, then it's a battery or connection issue. My old 1982 244 sometimes wouldn't crank because of the ground connection from the battery to the driver's side wheel well. That contact was corroded. Check out www.stepbystepvolvo.com, "Basics of Diagnosis and Other Hints," for a photo.
Sofar.
01-14-2014 01:42 PM
saltmiser
05-05-2009 08:08 PM
Redbeard76
03-15-2009 12:23 PM
qstyle
12-03-2008 06:37 PM
tlbacardi
01-06-2004 01:15 AM
Quick Reply: 82 245DL wont start
