83' Volvo 245 DL fuel pump relay problem
Old May 18, 2010 | 08:27 PM
treybohon's Avatar
Default 83' Volvo 245 DL fuel pump relay problem
I'm having a problem with my 83' Volvo 245 DL. I have replaced the fuel pumps, filter, and fuel pump relay. I can bypass the relay and it will start up and run fine. But, the in-tank pump stays on (because it's being bypassed). I have a genuine Volvo fuel pump relay but it won't start if I put the relay in the place of the bypass...
PLEASE HELP!
Old May 19, 2010 | 12:29 PM
bubba240's Avatar
take a close look at fuses 5 and 12, and the blade fuse by the coil.
Old May 19, 2010 | 02:03 PM
treybohon's Avatar
fuses 5 and 12 are fine and the blade type fuse by the coil is not broken.
Old May 19, 2010 | 02:41 PM
bubba240's Avatar
make sure the red wire that enters the relay has battery voltage, and the blue-red wire has voltage with the key on.
Sambar Stag
Sep 4, 2012 01:10 AM
volvoplay
Jul 16, 2012 07:03 PM
spidersilva
Aug 17, 2011 07:23 PM
montysano
Sep 9, 2008 11:52 AM
