83 volvo sittin 5 years what do i do to get her started?
Old Jul 4, 2009 | 09:34 PM
83 t brick's Avatar
Default 83 volvo sittin 5 years what do i do to get her started?
i need to know what all the proper procidures are to get my 83 244 turbo started... and does the cis fuel injection system really require that much maintnence? thanks
Old Jul 6, 2009 | 08:54 AM
adub96's Avatar
If its been sitting 5 years, the CIS fuel system will need to be completely taken apart, except the fuel distributor, never take that apart. Then you'll have to clean out every single line. Dollars to donuts your fuel pumps are done for also. After that replace all the fluids. Pull the plugs. Check the air filter. Probably need a new battery. Spray some oil down through the plug holes to the pistons. Let it sit. Turn the motor over preferably with the plus out so it doesn't start. put the plugs in and try to start it afterwards.
MikeToppin
Oct 22, 2011 06:20 AM
IsuzuFire
Jun 14, 2010 11:04 PM
m2point1
Jun 2, 2008 08:34 PM
98v70
Dec 6, 2005 01:25 AM
mattad
Aug 31, 2004 11:52 AM
