'85 245 with starting prob.
Old Dec 12, 2007 | 11:20 AM
Thegoose's Avatar
Default '85 245 with starting prob.
Over the last few months i've noticed problems starting our volvo 240 wagon. It's an '85 with 92k. The problem occurrs, I would say 50% of starts, and more commonly in the mornings.The car starts up but then immediately dies.Then other times it starts up no problem. If i give it a little gas while starting after it has cut off, it seems to run well until i let off the gas. Then sometimes is cuts out or other times it runs fine. A friend recommends cleaning the throttal body and changing the O2 sensor and possiblythe air flow meter.Of course i'll start cheap and work my way into the red. But does this sound like the road i needto be headingdown or change course??
Maxwell
Old Dec 12, 2007 | 11:53 PM
Gilfy's Avatar
Default RE: '85 245 with starting prob.
I have a '87 244 DL that is having the exact same problem. any input would be helpful [sm=WTFsgign.gif]
Old Dec 22, 2007 | 08:18 AM
Thegoose's Avatar
Just an update. My local Volvo shop diagnosed the problem as a bad Mass Air Flow Sensor...or MAF...or AMM. I called around and found a rebuilt MAF for alot lessthen new. Just pulled the old out and pluged the new in.Car starts great and is running better than it has in years. Good luck.
supaman658
Jan 15, 2007 09:31 PM
c70turbogt
Nov 16, 2006 08:42 PM
CincyStateFreeze
Sep 10, 2006 01:32 AM
MrD
Jan 1, 2006 05:16 PM
moonraker
Jan 2, 2005 11:23 PM
