86 240DL radiator overheating. Need help
Old Jul 19, 2006 | 12:32 AM
jktiffin's Avatar
Default 86 240DL radiator overheating. Need help
Every now and then the temp gauge rises to just below the red line; at which point I turn on the heater and it goes back down. I have not noticed when this happens but it is sporadic. The coolant was flushed 6 weeks ago when I bought the car so that should be OK, and it has not been hot here. Any ideas as to the most likely problem? and how to solve?
Thanks
Old Jul 19, 2006 | 12:46 AM
Default RE: 86 240DL radiator overheating. Need help
It might not be overheating. It might just be the compensation board.
Old Jul 19, 2006 | 12:53 AM
jktiffin's Avatar
Tech,
What is that, what does it do and how would I check to see if that indeed is the problem?
Thanks
Old Jul 19, 2006 | 01:18 AM
It controls Voltage to the Temp Guage.
The only way I know of to check is to bypass it and see if it still does it.
You will need to remove the speedometer cluster and then remove the Compensation board and Jump pins 1 and 3 with a piece of wire.
Old Jul 20, 2006 | 09:24 PM
wojeepster's Avatar
instructions:
http://www.ipdusa.com/pdf/PI-297TempBypassKit.pdf
akpasta
Apr 20, 2014 02:14 AM
dman777
Mar 10, 2010 08:28 PM
rdmb1512
Aug 7, 2008 08:59 AM
uniquemicro
Mar 4, 2008 12:18 PM
jktiffin
Feb 21, 2008 07:37 PM
