'86 B230FT no injector pulse
Old Jun 23, 2019 | 04:19 PM
cabinover's Avatar
Default '86 B230FT no injector pulse
Kind of stuck here so any help would be much appreciated. I have a no start condition on my 760. Car has sat around for many years so I just pulled the intank fuel pump and replaced it as well as flush the system. Injectors were stuck so I pulled them and got them working again on the bench however they will not fire in the engine. I have 12VDC on the green but no ground ever. Does this ground signal come from the ECU?
If I power up the ignition and hit the grey wire with ground the injectors are doing their thing.
Another question...dropped one of the injector tips (green plastic things that probably have a proper name) into the head. Must have went down into the cylinder since I can't see it although I wouldn't think the valve would open far enough so maybe it's just hidden on the close side and a small mirror will find it. I don't need it as I have new orings and these parts to put on and I would imagine it would just break up and go out through the exhaust. Any reason for concern?
Thanks!
940gnome
Nov 7, 2017 05:49 PM
Steven Hughes
Jan 24, 2016 08:06 PM
Tony Villa
Oct 4, 2012 06:31 PM
lesrrt
Dec 24, 2006 05:17 PM
lleroyb
Oct 12, 2005 10:57 PM
