'86 Volvo 240DL "Brake Failure Light" Sensor Replacement
Hello, New to the Forum and looking for some advice/ knowledge.
I got a 1986 Volvo 240DL
My issue that the "Brake Failure Light" Sensor is leaking on the brake fluid junction box.
Is there a gasket or washer I can replace?
Can I just replace the Sensor?
OR
Do I HAVE to replace the whole junction?
Thanks for any replys
OR
And if you wanted to avoid replacement - you might be able to find a steel or brass plug that will fit where the plastic cap with terminal is (where it's leaking from) . Remove that plastic, screw a plug on (maybe a tapered tread plug). That will stop the leak. Of course when you step on the brake pedal and the pedal goes to the floor because there's no brake fluid, or the master cylinder is really bad - you won't get a red light on the dash that means - HEY YOUR BRAKE PEDAL JUST WENT TO THE FLOOR!
VinnyVolv (02-14-2022)
cisopen
09-20-2010 05:25 PM
