'86 240 alternator replacement question
Old Apr 13, 2010 | 12:15 AM
Otis's Avatar
Default '86 240 alternator replacement question
After following the Haynes charging system troubleshooting guide, I ordered a new alternator, but I can't figure out if Bosch drastically changed their design, or the fella gave me the wrong alternator. The connectors on the back are not the same as the original, which had the B+ battery connection, the smaller connector for the dash light, and the ground strap. This new one looks nothing like it - It only has the big B+ and some sort of black plugin slot. Should I take it back and get the PPS brand alternator?
On a related note, my alternator to dash indicator wire is pretty frayed. Can I replace it with a jumper between the two points, or is their some other component along the way that I am missing?
Old Apr 13, 2010 | 10:44 AM
bubba240's Avatar
That doesn't look like the correct one ... I would take it back.
the.one
Sep 13, 2011 08:37 AM
300td
Jun 15, 2011 06:47 PM
potsiewebber
Sep 12, 2009 01:54 PM
realtor123
Oct 13, 2008 09:12 AM
jvolvo850
Oct 10, 2008 04:23 PM
