88 240 fuel system problem
Old Sep 29, 2008 | 01:50 PM
virginiabowen's Avatar
Default 88 240 fuel system problem
I have an 88 volvo 240 and it won't stay running unless I clamp off the reverse fuel filter line...then it runs. I have replaced the filter, the fuel pump, the relay and have no idea what the problem is. If I remove the clamp from the reverse fuel system hose the car dies. Please help.
Old Sep 29, 2008 | 03:09 PM
bubba240's Avatar
Default RE: 88 240 fuel system problem
You have a clamp on the fuel return line (which is taking gas back to the tank)? Sounds like maybe an issue with the fuel pressure regulator ..
Old Sep 29, 2008 | 05:31 PM
blue goose's Avatar
I don't know what the reverse fuel filter line is. As bubba says, if you have the clamp on the fuel return line from the fuel pressure regulator, you should check or replace the regulator. Check it by pulling the vacuum line off the front of it and sniff for gas. If gas leaks out or if there's gas in the vacuum line it's a bad regulator.
inilegna
Sep 25, 2013 03:27 PM
Kabwemech
Jul 18, 2013 06:33 AM
brian@travispace.com
Jul 23, 2011 06:17 PM
bspark1
May 24, 2010 12:12 PM
