S80T6 2000 model Fuel system problem
Old May 18, 2010 | 02:38 AM
bspark1's Avatar
Default S80T6 2000 model Fuel system problem
I have an S80T6 that continues to give me fuel system problems. I have had the throttle cable cleaned out, the ECU shows that the oxygen sensor may be the problem. The vehicle basically drives beautifully for weeks on end and then if its parked down a hill with the front end pointed down the hill it fails to start properly and seems to be sucking for fuel until it stalls. It is now at the stage where every so often when driving along it does the same thing and sucks for fuel until it stalls. The current mechanic thinks it may be the oxygen sensors before the cat convertor but doesn't guarantee it will fix the problem. I took it to another mechanic and he states its possibly the fuel pump. Any ideas as its really pissing me off because the car drives so beautifully and then this re occuring problem takes place and then the next day the car is back to normal.
Old May 18, 2010 | 09:15 PM
SVTfocusO3's Avatar
Call your dealer and see if this thing is under fuel pump warranty or recall 220. Some vehicles exhibit this problem.
Or email VIN, ill check:
volvosupport7279@hotmail.com
Old May 21, 2010 | 08:46 AM
bspark1's Avatar
Default S80T6 2000 model fuel system problem
The Vin Number is YV1TS90K5Y1100918, the thing just shat itself again tonight, it seems that it is happening more frequently.
Old May 24, 2010 | 12:12 PM
SVTfocusO3's Avatar
That VIN is giving me a problem checking it with Volvo, although it is a good VIN, I have never seen this before.
Check all your hoses under the hood and make sure no leaks, I will look into this VIN.
johnandgayna
Nov 1, 2013 07:39 PM
edahlgren
Feb 10, 2011 09:09 AM
bspark1
Mar 11, 2010 06:51 AM
jonc123
Feb 17, 2010 03:59 PM
edahlgren
Sep 5, 2009 03:45 PM
