88 240 Tie Rod Nut Type: Nylock or regular?
Old Mar 8, 2011 | 01:34 AM
jigen3's Avatar
Default 88 240 Tie Rod Nut Type: Nylock or regular?
hi,
been replacing the front suspension parts on my '88 volvo 240. i originally ordered a tie rod from fcp that turned out to be a flennor and the nut on it was just a regular hex nut, then i returned it and got the TRW/moog tie rod and it didn't come with any nuts.
was wondering the kind of nut that goes on the tie rod, is it just a regular hex nut? been hearing that nylock is a good choice to go on tie rods from other forums...
the original ones on my car are frozen but appear to be just regular nuts. (also anyone know a good source for yellow zinc plated metric fasteners? i know of eagleday but they don't have any m14 nuts and selection is a bit limited)
any input about this would be really helpful thanks
Last edited by jigen3; Mar 8, 2011 at 08:55 AM. Reason: got source of tie rods wrong
Old Mar 8, 2011 | 02:14 AM
TIPSP's Avatar
Got Boost?
The tie rods from trw and moog are suppose to come with the nylock nuts (which is what i used). Where did you get them? call and tell them to send you the nuts.
TrueValue usually stocks them. I even think do-it-center might carry them.
Old Mar 8, 2011 | 08:16 AM
jigen3's Avatar
got them from fcp...yeah i got some clear zinc nylock nuts from the local fastener store as well as reg. hex nuts, but kind of holding out for a source for yellow zinc ones
Last edited by jigen3; Mar 8, 2011 at 08:55 AM. Reason: got supplier of tie rods wrong
Old Mar 10, 2011 | 01:01 AM
Titan Joe's Avatar
Are you talking about the tie rod, or the tie rod end?
Old Mar 10, 2011 | 11:33 PM
jigen3's Avatar
the nut that goes on the tie rod to keep the tie rod end in place....it doesn't go on the tie rod end.
anyway, i called fcp and they said that it the moog tie rod doesn't come with a nut, but recommended to use a nylock.
Old Mar 11, 2011 | 09:08 PM
TIPSP's Avatar
Got Boost?
oh.. I just used the regular nut to hold the tierod in place.
nylock holds the tie rod end to the steering knuckle
Old Mar 11, 2011 | 09:35 PM
swiftjustice44's Avatar
That's just a keeper nut...doesn't need to be a lock nut. As has been pointed out, the tie rod end to knuckle should definitely be a nylock.
Old Mar 12, 2011 | 02:37 AM
Titan Joe's Avatar
All that nut does is locks the adjustment. To put a nylock nut on the rod would be very hard since the nylon side would have to go on first.
Old Mar 12, 2011 | 10:48 PM
jigen3's Avatar
just been looking at the nut again, and been learning about nuts, and i have a strong feeling it's a jam nut. looking online it seems they are common on tie rods, will try to confirm with the local fastener store tomorrow...
Old Mar 14, 2011 | 10:09 PM
jigen3's Avatar
no, it's just a regular m14 hex nut
jigen3
Mar 21, 2012 07:18 AM
ricbelley
Oct 26, 2009 05:30 AM
fredbyte
May 26, 2009 01:44 PM
Philly240
Mar 18, 2009 02:55 PM
vwdodge
Mar 2, 2005 06:45 PM
