88' 740 transmission Issues?
Old Mar 7, 2010 | 06:07 PM
Cobra_03's Avatar
Default 88' 740 transmission Issues?
Guys I have a 88" Volvo 740 Turbo wagon with about 260K. Here is my problem...
Last night I noticed that 4th gear(overdrive) would really act up when I would step on the gas. When kicking down into 3rd gear it would rev way up then engage? Not right!
I ignored it buy turning off the overdrive and proceeded to drive it a little more today. As I was headed to work to pull a overdrive solenoid of my parts car I wanted to see if the car would act up again.....
It kicked down to 3rd, revved then all the sudden I had nothing. It would just rev in "Drive", wouldn't engage in reverse nothing?? Moving the shift selector I could get "Park" and "Neutral" to work fine.
I checked the oil level and it seemed fine. I was a little concerned about how dark the ATF was, but it didn't smell burnt and still had a red color to it.
I have no idea on the mileage of the transmission or if it has ever been changed out?
What do you guys think I should do? Mess with this tranny and make it work or use a used tranny, which I have in my parts car?
Any advice would be great!
-Todd
Old Mar 8, 2010 | 05:04 AM
Typhoon's Avatar
The only way an auto will miss a shift or flare on a downshift is incorrect fluid pressures or a valevbody problem.
Losing everything indicated a fluid pressure/flow problem.
Since it is cheap and easy to do, I would drop teh pan, change out teh fluid AND filter and see what happens.
Regards, Andrew.
olddaddy
Jul 31, 2009 03:52 PM
knoman
Jun 23, 2009 08:56 AM
tenchu
Mar 12, 2008 07:51 PM
rainier34
Sep 10, 2006 02:55 PM
