'89 240 transmission quit
Old May 21, 2012 | 11:32 AM
RA091224's Avatar
Banned
Default '89 240 transmission quit
I was in creeping traffic for 20 minutes and suddenly the '89 240 transmission wouldn't go into any gear. I turned off the engine waiting for a tow and turned it back on 20 minutes later and it worked perfectly...drove home in city traffic. Thank you for your observations
Old May 21, 2012 | 01:20 PM
Is this an automatic or a stickshift ?
if its an automatic, I'd be looking at the ATF first, is there enough? is it ancient and burnt smelling?
Old May 22, 2012 | 09:00 AM
RA091224's Avatar
Banned
Default 89 240 Transmission quit
It's an automatic. The ATF was full and normal, no burnt smell. The shift lever moved freely into all positions, none of which worked. The shift does have a little play in each position.
Old May 22, 2012 | 09:34 AM
play in the auto shifter is normal
hard to guess whats wrong from the symptoms, I wouldn't know where to begin diagnosing this. the auto in these cars is an Aisin-Warner AW70, a very robust transmission used in a number of larger Toyotas from the same vintage. i'm guessing it got very hot, then when it cooled down it started working again, but not shifting at all is unusual, I'd more expect behavior like slipping bands causing loss of power.
Old May 22, 2012 | 10:43 AM
bubba240's Avatar
when is the last time the ATF was changed?
Old May 22, 2012 | 01:00 PM
indeed, I'm thinking, not just a ATF flush, but dropping the transmission pan and cleaning it out carefully and thoroughly. this is something I usually leave to a good transmission shop, but its not a cheap service. It probably should be done every 100K miles or so just on principle.
Old May 22, 2012 | 04:14 PM
RA091224's Avatar
Banned
Thanks for the suggestions. I bought the car last year and don't know when the ATF was last changed, if ever, or the pan cleaned out.
Old May 22, 2012 | 05:12 PM
bubba240's Avatar
take a look:
aw70
Old May 22, 2012 | 05:22 PM
$20, eh? you price ATF recently? eek.
I've heard 12-16 quarts to get a good flush, especially if the tranny had been neglected for awhile. also, one quart out, one quart in, rather than flush til sputter, fill and repeat.
Old May 23, 2012 | 10:49 AM
bubba240's Avatar
Yeah I agree, 1 quart at a time. That site is really old, I think Walmart's generic 4 quart ATF is ~$16 where I live.
akpasta
Mar 2, 2014 04:00 PM
Magic_Don
Oct 1, 2012 04:56 PM
Magic_Don
Sep 4, 2012 04:42 PM
randytrish
Oct 19, 2010 05:51 AM
TylerG
Oct 10, 2005 01:16 PM
