89 740 turbo alternator
Old May 19, 2016 | 07:42 AM
marcofd89's Avatar
Default 89 740 turbo alternator
I'm wondering what's the right tension on the alternator belt, car runs fine just noticed a little squeak when I step on the gas.. Opened the hood and I see that the belt has a little play, just wondering what's the right tension and how to do it the right way.
Old May 19, 2016 | 07:58 AM
dytha99's Avatar
5mm to 10 mm deflection midway between alt pulley and crank pully. Belt is adjusted by tightening the 10mm bolt on the alt.
Old May 19, 2016 | 08:03 AM
dytha99's Avatar
YouTube video on a 940....
https://m.youtube.com/watch?v=QRSYYgNIqUc
Old May 24, 2016 | 04:37 PM
brickrunner's Avatar
Make sure that the three rubber bushings holding the alternator are in good shape. With time they start to wear causing you alternator to be out of alignment.
dnarby
Jul 8, 2013 12:16 PM
Mike740Turbo
Jul 4, 2012 02:53 PM
steelheaddan
Feb 5, 2011 06:54 PM
1Gray760T
Nov 13, 2009 08:19 PM
sventhevolvo
Oct 30, 2008 08:48 AM
