89 740GL Some instruments don't work: common cause?
Old Aug 15, 2016 | 09:38 AM
2Small2Fail's Avatar
Default 89 740GL Some instruments don't work: common cause?
Hey everybody, new here, thanks for being here! I have a 1989 740GL with close to 400,000 miles, still runs pretty well. I started having to smack the dash a couple years ago to get the fuel and temperature gauges to activate, and that went fine for awhile until one day when I smacked the dash, the speedometer needle dropped to 0 and hasn't worked since. I've removed the instrument cluster since, to see if there's anything obvious (duh- of course there isn't) and now have several issues; neither the dash light, fuel gauge, speedometer or odometer work. The clock, tachometer and temperature gauge all work fine. I'm wondering if there could be a common cause to this. I will say I believe I got the center connector behind the instrument panel plugged back in, but I'm not 100% certain. Fuses look good, so it's not that. I'm having some trouble locating an accurate troubleshooting guide for this sort of thing, and trying to avoid a trip to the $95/hr. mechanic fees if at all possible. Any info will be immensely appreciated.
Old Aug 16, 2016 | 01:07 AM
lev's Avatar
lev
I'd start with the circuit board. Refloat the solder points which are probably cracked, with a soldering iron or get another board. Make sure the plug is back in, naturally!
MNWILD
Jan 7, 2011 07:59 AM
calvinhoe
Dec 6, 2010 10:00 PM
Typhoon
Jul 11, 2010 10:18 AM
comrusk7
Jul 7, 2005 12:11 AM
Tecno88
Feb 10, 2004 01:14 AM
