90 240 Funky cold start problem
Old Dec 2, 2019 | 08:15 PM
  #21
spenc9310's Avatar
Originally Posted by PAVolvo850
My son recently began having this problem with his 90 240 wagon. When first cold starting, it cranks and runs very roughly, you can smell it dumping fuel. Then it chugs as if its hitting on maybe two cylinders. If you hit the pedal right away, it dies. However if you let it chug a bit, then try to gradually rev it up, it seems to help. It will belch a big black cloud, then run ok after that. If you fail to keep it going initially, it won't start again.
We both research extensively on the internet and found a few posts with EXACTLY the same symptoms, but No one EVER replied with the fix... EVER.
It's extremely cold here so there's not much time to be outside chasing our tails. lol
Ideas, things looked at;
It has a new cap, rotor and wires already. Also plugs.
FPR is ok, no obvious leaks thru diaphragm.
Brand new coolant temp switch was installed.
New In-tank fuel pump (AEM320) and the in-line pump deleted.
New fuel filter.
Replaced the ignition coil.
No vacuum leaks.
Thinking maybe injectors leaking?
No engine codes..
Ran diagnostic procedure.. everything ok and heard the injectors fire and the air idle solenoid working.
After the car is warmed up it will restart fine.
Any ideas are appreciated!
Cheers,
Mike
Did anyone solve this problem?
My ‘81 245 has the exact symptoms. Wants to stall on initial startup unless I speed up the idle a bit(getting much worse with the cold weather), after warmed up it starts fine.
Not sure if I have a cold start injector on this one.
Would love to hear any possible solutions.
Best,
Old Dec 2, 2019 | 09:17 PM
  #22
an 81 has completely different fuel injection than a 1990. In fact, an 81 might be K-Jet (CIS) rather than LH (EFI). K-Jet troubleshooting is a whole different game than LH...
Anasanjo
May 19, 2015 09:43 PM
92Sedan
Apr 25, 2015 04:13 PM
stokesrl
May 28, 2009 06:25 PM
mrscullini
Oct 30, 2007 11:23 PM
k8_is_great
Jun 2, 2005 01:24 AM
