'90 240 instrument lamps non-functional
Old Feb 21, 2005 | 12:35 PM
vinnievolvo's Avatar
Default '90 240 instrument lamps non-functional
Hi. I have a '90 240DL Sedan w/ 185K miles on it. Great car, bought it new and I'm still driving it after 15 years with original transmission and engine! However, one minor problem I have is most of the instrument bulbs have burned out, so at night its really hard to see the controls. How does one get at these lamps in order to replace them?
Old Feb 21, 2005 | 12:41 PM
Default RE: '90 240 instrument lamps non-functional
Im not sure 100% but I think they are just push in glass bulbs.Some you had to replace the entire socket with.Some were just replaceable bulbs.If they are the replaceable bulbs you can get them at walmart or a Auto Parts store.If you need the bulb and socket Import Auto Parts stores carry them.You wont know for sure till you take it apart.
Old Mar 26, 2005 | 03:22 PM
criley's Avatar
There are 2 bulbs in the cluster. The best way to get the bulbs is through the Volvo dealer. They run around $15 each unless you know someone that can get them at cost. Then they are around $6. Take out the cluster and the bulbs are at the top. Just twist a half tuurn and they will come out. It is not a big project and should only take you about 15 min.
Chris
Old Apr 4, 2005 | 10:40 PM
How do you get to the cluster???
Old Apr 5, 2005 | 02:07 AM
Pull the headlight **** and the dash dimmer **** off.Then the plastic cover.There is 2 screws there.On the other side remove the 2 square panels next to the cluster.There is 2 screws there remove the screws and the cluster will pull out.
Old Apr 5, 2005 | 10:20 PM
Thanks, I'll give it a try.
Old Apr 6, 2005 | 03:09 AM
Let me know how it goes.
Old Apr 6, 2005 | 12:50 PM
reg's Avatar
reg
Try Radio Shack for inexpensive bulbs. Simply take one of the bad bulbs to the store and pick up the replacements! BMW has some extremely costly dash bulbs and yet one can obtain them from Radio Shack for peanuts!
glm409
2001-2013 model year V70
Dec 22, 2014 08:55 AM
Aferthas
May 13, 2010 07:01 PM
Jim-1995 850
Jan 11, 2010 02:57 AM
richsid
Mar 25, 2008 01:01 PM
rmmagow
Apr 13, 2006 12:29 PM
