Are instrument clusters from turbo 850s the same as non-turbo?
Old Jan 9, 2010 | 07:19 AM
Jim-1995 850's Avatar
Default Are instrument clusters from turbo 850s the same as non-turbo?
My 95 850 GLT has a broken odometer. I saw a how-to thread about replacing the little plastic gear to fix it, but I found a 96 turbo 850 parts car that I'm already buying the dash cover from & could possibly buy the cluster as well.
Are there differences that will make this a no-go?
Thanks!
Old Jan 9, 2010 | 10:52 AM
gilber33's Avatar
Yes there is actually. Only clusters from 94/95 are interchangeable and clusters from 96/97. Between those years they changed how the speedometer receives its signal, making them non interchangeable. Sorry.
Old Jan 9, 2010 | 11:15 PM
Carrots's Avatar
Don't change your cluster! Buy the odometer gear from fcpgroton, IPD, or odometergears.com and fix it. You can pull the car's actual mileage from the computer (the how- to is in a thread somewhere) and set the cluster to the correct mileage, then change the gear with a new one, and everything will be happy. There's 2 kinds of odometers in an 850: one that's broken, and one that's about to break. And the former is the most common type to find in a salvage yard. Used odometers are truly a false economy on these cars.
Old Jan 11, 2010 | 02:57 AM
Thanks, that's exactly what I decided to do & already ordered the new gear off eBay for $14 shipped.
hga
Mar 21, 2014 11:08 PM
Amir Ghadiri
Jan 24, 2013 12:44 PM
I am Phil
Dec 29, 2011 12:51 AM
HummerGuy
Apr 10, 2009 08:15 AM
coltdunkley
Sep 2, 2008 06:15 PM
