90 240 starts then stalls
air leaks anywhere between the MAF and the intake manifold can lead to stalling at idle. also check the idle air controller and its short little hoses, thats under the intake manifold.
that air hose from the exhaust isn't important except to pass emissions in states that inspect such things (<cough>Caliifornia</cough>)
both pumps are wired together and as long as the engine is running, they both should run. when you first turn the key on, they run for about 1 second then stop until you crank the engine over.
xDread92x
08-18-2012 03:18 PM
donotpress
07-08-2011 10:19 AM
