90 240l horn goes continously
Old Feb 16, 2013 | 03:56 PM
dkzon4u's Avatar
Default 90 240l horn goes continously
ive recently replaced the heater blower motor on this car and when i got it back together the horn goes continously when i turn the key on. anyone have a clue as to what i might of done wrong putting it back together thanks and would appreciate any input dave
Old Feb 16, 2013 | 05:13 PM
the horn circuit is pretty simple. ignition key pin "X" (on when in accessory or run), yellow wire to fuses 1,2.3. yellow wire from fuse 2 to horns. black wire from horns to horn switch in steering wheel, black wire from horn switch to ground. the horn switch is on a brush thing so it stays connected as the steering wheel is rotated.
if the horns are always honking, that black wire must be shorted to ground somewhere between the horn and the steering column..
fuse 2 is also used for the windshield washers.
Old Mar 1, 2013 | 10:38 AM
dkzon4u's Avatar
Thank you Pierce im just getting back to it today I think I can figure it out now
Old Mar 1, 2013 | 12:45 PM
jessica9012324's Avatar
It seems there is some problem with the horn. I have used Warning Light | Code 3 | Light Bar | Strobe Light | LED Lights to replace my horn. They offer very cheap price.
pancho
Nov 6, 2014 03:19 AM
92Typhoon
Oct 16, 2007 12:49 PM
sdat1333
Mar 18, 2007 03:18 AM
wakenine
Dec 1, 2006 02:17 PM
