'90 245 replaced diff cover problem
My new first time Volvo is a 90 wagon. The differential cover was leaking and I got what i thought was a good deal on an aluminum 740 cover. Had it replaced and now no speedometer.
The question is can a 740 cover (of unknown origin) work on a non-ABS 240 with manual trans? Or do I need to spring for a new steel one?
After the fact, I see the recommended clearance of the sensor is rather tight and the rusty cover had a paper type gasket and was replaced with a thick felt like one which would throw the clearance way out. Also, this may be wishful thinking but the odometer may flipped to the next tenth since it was changed though speedometer was was not noticed to be working at all.
My new first-time Volvo is a 90 wagon. The Diff Cover was leaking and I got what i thought was a good deal on an aluminum 740 cover. Had it replaced and now no speedometer.
After the fact, I see the recommended clearance of the sensor is rather tight and the rusty cover had a paper-type gasket and was replaced with a thick felt-like one which would throw the clearance way out. Also, this may be wishful thinking but the odometer may flipped to the next tenth since it was changed though the speedometer was not noticed to be working at all.
