94 5-speed won't go into 2nd gear
Old Apr 4, 2009 | 07:09 PM
netscarf's Avatar
Default 94 5-speed won't go into 2nd gear
Hi.
Just picked up a 94 850 base model wagon. I can't get it to go into 2nd gear. all it does is grind when I try. All other gears work good, and the clutch seems to function properly.
I don't have much exp. with manual trannys, so any ideas, and thoughts will be helpful.
Thanks, Gary
Old Apr 4, 2009 | 08:21 PM
Sounds the a problem in the transmission.
Old Apr 4, 2009 | 09:34 PM
dan2286's Avatar
I believe that is a bad synchro in the trans. Isnt there a way of shifting that would make him able to get into second without grinding? I think its called double clutching or something like that.
Old Apr 4, 2009 | 09:47 PM
That might work but sounds like it is an issue in the tranny with second. If it was just the synchro then it would grind but still go into gear.
Reefers4U
Jun 22, 2013 11:07 AM
Nirky
Aug 30, 2011 08:27 AM
89240DL
Mar 15, 2009 10:32 PM
Vee
Jan 13, 2009 06:05 PM
407flyer
Jun 6, 2008 01:58 AM
