90 volvo 240 check engine help
Old Dec 5, 2008 | 07:51 PM
slolem66's Avatar
Default 90 volvo 240 check engine help
Read how to test the check engine light, but I have a, will crank, and no spark situation. Turn the ignition key on and all warning lights are on except for the check engine light. Put pin in #6 or #2 and press button light will come on strong when depressed hold a second and let go and then I will get no flashes. It appears i cannot comunicate with the ECM.. could it be a bad ECM or some other fuse or relay... THanks for any help.. Greg.
Old Dec 6, 2008 | 04:33 PM
billofdurham's Avatar
Default RE: 90 volvo 240 check engine help
Welcome to the forum.
This link will take you to a full how-to use the diagnostic system including what to do if it doesn't flash. Scroll down to pages 5 & 6.
http://www.matthewsvolvosite.com/for...c&start=12
It does apply to your car although headed for the '92 740 turbo.
240nut
Jul 5, 2013 08:31 PM
MarkInTexas
Apr 5, 2011 12:40 PM
beast_wit_ze_least
Oct 2, 2007 03:13 PM
chris1kanobi
Nov 4, 2005 09:26 PM
