90' wagon tailgate / electrical work issues?
Old Oct 6, 2008 | 07:22 PM
flac124's Avatar
Default 90' wagon tailgate / electrical work issues?
I have a bit of electrical work to do on my newly purchased 90' 240 Wagon. All the wires running back through the tailgate hinges have been slice. In checking the wire I have discovered that all but one of the wires have no power running through them? I checked the fuses, which look okay yet the lead running off the fuse box aren't showing any juice either? Am I missing something? Could it be a bad relay?
Old Oct 7, 2008 | 12:58 PM
fredbyte's Avatar
Default RE: 90' wagon tailgate / electrical work issues?
You have to get a good wiring diagram and trace backwards to a point where you're supposed to get 12 VDC (ignition "On," not "Start"). From that point, also do a continuity test (beep from a digital multimeter, diode setting) from that point back to the tailgate-meaning if your wiring is fine, you should hear a beep. You probably have a break at some point in the wiring or a faulty relay.
simonhf
Dec 1, 2014 04:28 PM
steve_o
Feb 22, 2013 03:12 PM
piv15
Jul 19, 2012 05:39 PM
Juneappal
Jul 11, 2007 11:10 AM
yellow95
Apr 19, 2006 09:05 PM
