91 240 aftermarket stereo
Old Aug 1, 2014 | 01:26 PM
volvoFETT's Avatar
Default 91 240 aftermarket stereo
so my factory stereo just crapped out on me after 23 long years of life. ive got a used aftermarket stereo that im trying to install. ive got a harness the fits kind of but need to rewire the harness itself and move some wire prong thingys around> but im having no luck find a wiring diagram that matchs the wires and wire colors I have. everything is factory stock in car nothings been changed. please help!!!!!
Old Aug 1, 2014 | 01:45 PM
did your car have the stereo upstairs with an eq/amp at hte bottom, or just a stereo upstairs, or just a stereo at the bottom? I've seen all 3 configurations on 240s. also, what speakers did the stock come with? our 87 240 sedan just had front door speakers wired, no rears at all.
I have the greenbooks for most years of 240, so if you answer, I can hopefully find the right diagrams.
Old Aug 1, 2014 | 01:52 PM
volvoFETT's Avatar
upstairs stereo not sure about the amp front and rear speakers in doors. I can open up dash real quick if it helps. the stck stereo had a black harness with 14 prongs 7 on top 7 on bottom but only 7 have wires going to them. ill post pics in a few mins
Old Aug 1, 2014 | 01:54 PM
ok, and hmm. 1991 240 greenbook wiring diagrams only list "Radio with extra amplifier and power antenna'. this is with the stereo on top and the amp/equalizer on the bottom.
on top, at the radio... 2 blacks are ground. green is fused always-on power. yellow-black is fused ignition/accessory power. red is antenna control. blue-white is dimmer. brown is rheostat+ (I doubt you can use this on an aftermarket stereo, so tape off and leave disconnected).
at the bottom, on the original amplifer, 2 blacks are ground. 2 greens are unswitched power. yellow-white and white are front-left speaker. yellow-grey and grey are front-right speaker. yellow-brown and green-brown are rear-left speaker. yellow-green and green-grey are rear-right speaker. (each speaker, I list + then -).
the two units were connected with a proprietary DIN connector.
if it was MY car, I'd put the stereo in the bottom slot (you can get a DIN adapter panel that fits into it), and find a factory 'pocket' for non-radio 240s to put in the odd shaped top slot, for keeping your sunglasses or whatever. I don't like bright colored stereo lights in my face at night, and I like my stereo discretely tucked away out of easy view.
Old Aug 1, 2014 | 01:59 PM
volvoFETT's Avatar
thank you so much that helps a whole bunch. a little more involed then I was hopeing but its what has to be done I cant drive without music. thanks again man and thank for quick response
Old Aug 1, 2014 | 02:00 PM
oh, the diagrams show the rear speakers are wired to a connector over above the gas pedal.
the amplifiier should be in the very bottom of the console, below the ashtray, forward of the gear shift. according tot he wiring harness drawing, there's a 'Y" harness, one plug goes to the radio unit, another goes to the amplifier, and te other end of this cable has two connectors near the gas pedal, one with front speakers and power-etc, and the other with rear speakers. the wire colors should be the same on both sides of these connectors.
Old Aug 1, 2014 | 02:03 PM
volvoFETT's Avatar
thanks. this is gonna be a long day
Old Mar 13, 2016 | 08:02 PM
otokoto's Avatar
Default Volvo 240 Equalizer
Hi Pierce, I am planning to add the factory Equalizer down at the bottom of the console of my 1993 Volvo 240, first, how do I install the Equalizer unit there, I have a like a storage with felt on it, second, how do you wire it to my original radio with cassette in it, all I can see is a wire with 6 pin connector and a RED wire. Do you think its compatible to my radio? thanks
Old Mar 13, 2016 | 09:45 PM
no idea, our 240 came without any factory stereo, I've intsalled aftermarket stereos in it since new (I think we had a total of 3 over the years)
ogsrotag
Dec 18, 2018 10:22 PM
adamdallas
Apr 5, 2010 10:52 AM
phoneman
Feb 3, 2008 07:54 PM
DEmodulatorAD
May 22, 2007 01:54 PM
kitties240sx
Aug 20, 2006 01:11 AM
